Most accurate way to get elapsed time (in microseconds) on iMX6?
ソリューションへジャンプ
3,285件の閲覧回数
EdSutter
Senior Contributor II
The gettimeofday() call returns microseconds.
Is this the most accurate method or is there a better way?
--EDIT--
I did a bit more snooping, and tried clock_gettime(CLOCK_MONOTONIC_RAW,&t1)
to get a timestamp.  This appears to be reasonably accurate.  Does anyone have any experience
with this to agree or disagree?
Thoughts?
Ed
タグ(1)
2,787件の閲覧回数
Hi Ed
proper to use clock_gettime, see below
c - Measure time in Linux - getrusage vs clock_gettime vs clock vs gettimeofday? - Stack Overflow
https://blog.habets.se/2010/09/gettimeofday-should-never-be-used-to-measure-time
chip
2 返答(返信)
2,788件の閲覧回数
Hi Ed
chip
2,787件の閲覧回数
EdSutter
Chip,
Yep, that's what I ended up using.  Shoulda posted it a while back.
Ed
