Hi @pengyong_zhang ,
As I mentioned before, I saw one failing lpddr4x sample with RD_TO_PRE 15
>>> Could you please tell more about this fail LPDDR4X sample? What test did you run or anything other situation?
<<< the lpddr4x sample was failed with memtester.
Does same RD_TO_PRE setting make the different effect on LPDDR4 and LPDDR4X?
>>> As i know, LPDDR4 and LPDDR4X only the VDDQ is different, So i think same RD_TO_PRE setting make no different effect on LPDDR4 and LPDDR4X.
<<< then, what's the reason of the imx93 reference manual shows different definition between LPDDR4 and LPDDR4x?
Thanks.
