Minimum resolution of HDMI output in i.MX8M
已解决
跳至解决方案
1,564 次查看
ko-hey
Senior Contributor II
Hi all,
I have a question about resolution of HDMI output for i.MX8M.
I can find a maximum resolution for i.MX8M but can't find minimum resolution.
Is there any information of minimum resolution for i.MX8M ?
Ko-hey
1 解答
1,451 次查看
joanxie
minimum resolution depends on the HDMI minimum pixel clock which is 27MHz. so if your resolution more than 27Mhz, i.mx8MQ can support it
在原帖中查看解决方案
1 回复
1,452 次查看
joanxie
