Migration Guide from Dialog PMIC to MC34708 for i.MX53
1,590 次查看
ScottKerstein
Is there a migration guide for the changes involved in moving from the Dialog PMIC to the MC34708 for an i.MX53 applicaiton?
Basically looking for hardware checklist in the changes and possible BSP changes for either Linux or Microsoft CE.
Thanks in advance.
Scott
标签 (3)
1,426 次查看
CommunityBot
Community Manager
This an automatic process.
We are marking this post as solved, due to the either low activity or any reply marked as correct.
If you have additional questions, please create a new post and reference to this closed post.
NXP Community!
1,427 次查看
CommunityBot
Community Manager
NXP Community!
1,426 次查看
maxmustermann
What's the actual problem to solve ?
Do you have some really special configuration or just need to get some common board running ?
I've got an TQMA53-board fully running on linux-4.0.3.
Well, almost fully running - except the GPU, because FSL keep the necessary specs a secret,
so we simply can't use it. (and i'll yet have to find a proper way to completely switch it off, just
in case it might do something stupid).
Oh, and don't even think about using the proprietary kgsl stuff - it's DANGEROUS !
[imx53] WARNING! Do NOT use the proprietary GPU drivers / KGSL stuff - MAJOR RISK!
1,426 次查看
igorpadykov
Hi Scott
I am afraid such document is not available, but one can compare
pmic drivers checking Linux Manual mx53_start_linux.pdf in
IMX53_1109_LINUXDOCS_BUNDLE Linux BSP Documentation for i.MX53
