Mfgtools fails for larger rootfs.tar.bz2 file
ソリューションへジャンプ
2,580件の閲覧回数
guna007
I am trying to load custom build rootfs.tar.bz2 and zImage into eMMC memory using mfgtools-4.15. I am getting error at "send roofts". I am attaching the debug UART  log for reference.
Any help would be appreciated.
ラベル(2)
タグ(2)
2,323件の閲覧回数
Hi Gunasekaran
one can try to increase emmc partition size, using mksdcard.sh.tar
in mfg tools folder ..Profiles/Linux/OS Firmware. Also may be recommended
to recheck memory with ddr tester
https://community.nxp.com/docs/DOC-10565
and rebuild mfg tools firmware with new calibration settings found from test
using attached Yocto Guide sect.6.2 Manufacturing Tool, MFGTool
2,324件の閲覧回数
Hi Gunasekaran
