Mfgtools fails for larger rootfs.tar.bz2 file
2,562 次查看
guna007
I am trying to load custom build rootfs.tar.bz2 and zImage into eMMC memory using mfgtools-4.15. I am getting error at "send roofts". I am attaching the debug UART  log for reference.
Any help would be appreciated.
标签 (2)
标记 (2)
2,305 次查看
igorpadykov
Hi Gunasekaran
one can try to increase emmc partition size, using mksdcard.sh.tar
in mfg tools folder ..Profiles/Linux/OS Firmware. Also may be recommended
to recheck memory with ddr tester
https://community.nxp.com/docs/DOC-10565
and rebuild mfg tools firmware with new calibration settings found from test
using attached Yocto Guide sect.6.2 Manufacturing Tool, MFGTool
2,306 次查看
igorpadykov
Hi Gunasekaran
