MfgTool2 Error
MfgTool2 Error
2,118 次查看
freewaymad
I am trying to use the MfgTool2 to load the android images I built and I get this error:
DLL version: 2.2.3
Monday, May 05, 2014 22:39:31   Start new logging
ModuleID[2] LevelID[1]: Parse ucl script failed, error code: 21
I modified the cfg.ini as outlined in the "Android Quick Start Guide":
[profiles]
chip = MX6Q Linux Update
[platform]
board = SabreSD
[LIST]
name = Android-SabreSD-eMMC
and that is when I get the error. I even tried it using Wine in Ubuntu 14.04 (Trusty) and I get the same error.
What is causing it and how do I fix it?
Thank you,
Dave
标签 (3)
1,212 次查看
Rita_Wang
Hi Dave,
Have you solved your problem now? If not, continue here.
Best Regards
Dan
1,212 次查看
freewaymad
Hi Dan,
I have kind of abandoned this for now. I have been working on this which I posted in the i.MX Community:
IMX6Q Tablet Problem
Dave
1,212 次查看
Rita_Wang
Hi Dave,
Which board are you using now?
Best Regards
Dan
