I have finally gotten MFGTool2 to write to the SABRESDB, but the result will not boot.
I deleted everything and started with a fresh install of "Mfgtools-Rel-1.1.0_121218_MX6Q_UPDATER.tar.gz".
The Android Quick Start Guide doesn't quite match the files in the distribution, so I am sure that some of the files used in my selection are wrong.
Can someone clarify which files should be used to load the SD card?
Since I can't see how full this card is, how big of a SD card is required to load the Android package?
