I m using iMX6SL-evk board. I want flash Yocto 4.9.88 images into EMMC.
I have downloaded L4.9.88_2.0.0-ga_mfg-tools.tar.gz mfg tool.
This is having with rootfs and without rootfs tools. I want to flash with rootfs.
I could not find VBS file related to my requirement.
Which is the perfect VBS file to flash yocto images into iMX6sl-evk EMMC device ?
Please provide me the guidance.
Thanks.
Solved! Go to Solution.
Hi Karthikeyan
i.MX6SL EVK has not emmc populated and it is connected to the same usdhc port
as sd, so there is no appropriate vbs script for it. One can try mfgtool2-yocto-mx-evk-emmc.vbs
and changing ucl2.xml and adding for LIST name="eMMC" codes for ifdev="MX6SL".
Hi Karthikeyan
