Hi Vaisag
sd/emmc routing rules are described in sect.3.6.8High speed signal routing recommendations
IMX6DQ6SDLHDG, Hardware Development Guide for i.MX 6Quad, 6Dual, 6DualLite, 6Solo Families of Applic...
There are no restrictions on length, however timings may be affected so necessary to
comply with requirements given in datasheet, for example sect.4.12.4 Ultra High Speed
SD/SDIO/MMC Host Interface (uSDHC) AC Timing
i.MX 6Dual/6Quad Applications Processors for Consumer Products - Data Sheet
