Hello, my application uses i.MX6Q as an CPU, but there is a need in live video transcoding. Using VPU of main unit is fine, but it allows only one thread, while we need three.
There is an obvious solution to use two more i.MX6S (as they are powerful enough to transcode fullHD and cost less, than DSP), but is there even more cost-effective solution using VPU, like separate VPUs or low-power CPU with several VPUs?
Solved! Go to Solution.
Hi Oleg
I am afraid there are no other special or non-standard solutions.
Hi Oleg
What a pity. Thanks though.
