Make pixel wise operation on framebuffer
1,309件の閲覧回数
JustinChou
Platform: IMX6  Android 4.4.2
I would make pixel wise operation on framebuffer (/dev/graphic/fb0, how to modify the driver? I want to resize, pan and rotate the content of framebuffer.
I have a Unity application program which will generate 1920x1080px60 LVDS output but it need to be warped, and I think software de-warping is an available solution.
Should I modify framebuffer driver directly?  If I could look into some code examples that would be great.
ラベル(5)
1,292件の閲覧回数
joanxie
pls refer to the enclosed sample code, hope helpful for you
This sample code for CSC settings for /dev/fb1.
It can calculating the CSC matrix and updates in real time from given parameters(Brightness,Contrast,Saturation,Hue, and gamma).
