MY-I.MX6-EK200 development board datasheet
715 次查看
cherryzheng
EK200 Front View
EK200 Rear View
MY-I.MX6 development board is a 4-layer mother board, strict EMC EMI design, high quality, stable and reliable, easy secondary development, convenient for customers to quickly develop their own products.
Icon module
Graphic
Interface description
Silkscreen
Graphic
Silk screen
1
18/24bit LVDS0
J11
19
RTC_Licell
BT1
2
18/24bit RGB
J15
20
UART5/TTL
J16
3
18/24bit LVDS1
J19
21
UART4/TTL
J14
4
10M/100M Ethernet
P1
22
GPIO
J13
5
Audio
J26
23
UART3/TTL
J12
6
HDMI
J23
24
UART2/TTL
J10
7
USBOTG
J25
25
SPI2
J9
8
PWR_SATA
J27
26
SPI1
J8
9
SATA
J20
27
MIPI_CSI
J7
10
USBHOST
J21
28
CMOS_CSI
J6
11
UART1/RS232
P2
29
CAN2
J5
12
PWR_Switch
J24
30
CAN1
J4
13
DC_5V_IN
J22
31
I2C3
J3
14
nRESET
SW4
32
I2C2
J2
15
KEY1
SW3
33
I2C1
J1
16
KEY2
SW2
34
SD3
J18
17
KEY3
SW1
35
WIFI
U8
18
SD2
J18
36
PCIE
J29
18/24bit LVDS0
  Silk screen:J24
  LVDS0 crystal liquid is 24 bit mode,compatible with 18bit mode,through which LVDS resistance screen panel and LVDS capacitor screen panel in different sizes and specifications produced by MYZR can be cnnected。LVDS0 interface block is build with connector imported,abandon the cheap drawer type produced domestically,which is opposite press type to ensure easier installation,better performance and connectivity 。
  definition of pin & signal as below:
(pin)(singnal)(description)
J24-16SD1_DAT1/TOUCH_nEINT1(GPIO control)
J24-17NANDF_CS3(GPIO control)
J24-19DISP0_CONTRAST(LVDS0 backlight adjustment)
J24-21TOUCH_SCL(I2C clock)
J24-22TOUCH_SDA(I2C data)
18/24bit RGB
  silkscreen:J23
  RGB crystal liquid is 24bit mode,compatible to 18bit/16bit mode,through which RGB resistance screen panel and RGB capacitor screen panel in different sizes and specifications produced by MYZR can be cnnected,RGB interface block is build with connector imported,abandon the cheap drawer type produced domestically,which is opposite press type to ensure easier installation,better performance and connectivity。
  definition of pin & signal:
(pin)(signal)(description)
J23-31SD1_DAT1/TOUCH_nEINT1(GPIO control)
J23-30NANDF_CS3(GPIO control)
J23-19DISP0_CONTRAST(LVDS0 backlight adjustment)
J23-32TOUCH_SCL(I2C clock)
J23-33TOUCH_SDA(I2C data)
18/24bit LVDS1
 silk screen:J22
  LVDS1 crystal liquid interface is the same as LVDS0 in terms of definition and connector model,users can connect crytal liquid in LVDS0 directly to LVDS1。
J22-16SD1_DAT1/TOUCH_nEINT1(GPIO control)
J22-17NANDF_CS3(GPIO control)
J22-19DISP0_CONTRAST(LVDS0 backlight adjustment)
J22-21TOUCH_SCL(I2C clock)
J22-22TOUCH_SDA(I2C data)
10M/100M Ethernet-1
silk screen:P4
interface property:100 - Mbps Ethernet standard interface
earphone output
silk screen:J20
interface property:audio signal output,3.5mm interface
microphone input
silk screen:J18
interface propoerty:audio signal input,3.5mm interface
HDMI
silkscreen:J5
interface property:HDMI-1.4 standard interface
SATA power supply
silkscreen:J12
J12-15VIN(5V power input)
J12-2GND(digital)
J12-3GND(digital)
J12-4NC(unconnected)
OTG
silkscreen:J5
interface property:USB ON-The-GO,for burn and write
SATA II
silkscreen:J11
interface property:3Gbps SATA II standard interface
10M/100M Ethernet-2
silkscreen:P3
USB expansion
silkscreen:J8
interface property:USB1 expanded to dual USB,standard USB interface
debug uart
silkscreen):P2
interface property:3 thread standard RS232 port,for debug of sirial port
main power supply switch
silkscreen:J3
interface property:power supply switch
status property:—,close;O,off
silkscreen:J4
interface property:
    jack with inside positive and outside negative
 voltage:5V
current:2.5A or a
reset
silkscreen:SW1
function:reset
wake up
silkscreen:SW2
interface property:sleeping wake up
volume up
silkscreen:SW3
interface property:volume control(volume up)
volume down
silkscreen:SW2
interface property:volume control(volume down)
RS-232 serial port
silkscreen:P1
interface property:UART4,3 thread standard RS232 port
RS-485 serial port
silkscreen:J2
interface property:UART3,RS-485 serial port
MINI-PCIE
silkscreen:J6
interface property:standard MINI-PCIE port
serial port expansion/TTL electrical level
silkscreen:J1
GPIO/SD2
silkscreen:J4
SPI expansion
silkscreen:J7
SIM cassette
silkscreen:CON1
interface property:standard SIM cassette
MIPI-CSI
silkscreen:J9
CMOS-CSI
silkscreen:J14
CAN2
silkscreen:J16
interface property:CAN2
CAN1
silkscreen:J19
interface property:CAN1
I2C expansion
silkscreen:J21
GPS antenna pedestal
silkscreen:E4
interface property:antenna pedestal
GPS
silkscreen:U15
module model:NEO-6M
MINI_PCIE_FPC
silkscreen:J26
note:can't be used with MINI_PCIE simultaneously,e.g can only choose one from the two。
SD3
silkscreen:J25
interface property:standard SD cassette
WIFI
silkscreen:U16
module model:UM12BS
RTC
silkscreen:U19
interface property:real clock for I2C communication
RTC_Batter
silkscreen:BT1
If you would like to know more our product, please visit www.myzr-tech.com or email to enquiry@myzr.com.cn
0 回复数
