MX8MN doesn't support dek blob length higher than 128Bits
MikeEngel
We have successfully implemented u-boot encryption. We can encrypt and sign the SPL and the FIT of the u-boot with 128Bit dek blobs. But when we tried to use 256Bit the dek_blob command didn't worked.
Is their  any information about a dek blob size limit for the MX8MN?
Mike
Yuri
@MikeEngel
  The issue is discussed internally.
Yuri.
