when I process weston-simple-egl. the message is "init_egl: Assertion `display->egl.dpy' failed". I saw the code is initEGL faild. it is work on the Yocto. but debain is failed. please help me. thanks.
Hello Chen,
You should download the latest BSP where weston compositor not failed however you can check with our third party if debian work with it:
https://developer.solid-run.com/knowledge-base/i-mx8m-debian/
https://boundarydevices.com/wiki/debian-for-nitrogen8/
You should ask to our third party since debian its not supported by nxp.
Hello Bio_TICFSL
thanks for your answer. I try to downland debian-buster-sdhc img. bug it can not boot from MMC
U-Boot SPL 2018.11-08002-g8e521a3525 (Nov 20 2019 - 16:49:56 +0000)
PMIC: PFUZE100 ID=0x10
Training FAILED
Training FAILED
Training FAILED
Normal Boot
Trying to boot from MMC2
MMC Device 1 not found
spl: could not find mmc device 1. error: -19
SPL: failed to boot from all boot devices
### ERROR ### Please RESET the board ##
