Please note that for the MIPI panel to be tested with our demo image you'll need to select the correct device tree:
Android
dtbo-imx8mm-mipi-panel.img
Linux
Image-fsl-imx8mm-evk-rm67191.dtb * LPDDR4 EVK
Image-fsl-imx8mm-ddr4-evk-rm67191.dtb * DDR4 EVK
Hope this helps,
Aldo.
Aldo Gutierrez wrote:
Please note that for the MIPI panel to be tested with our demo image you'll need to select the correct device tree:Android
Thank you for this suggestion, but how do I do that?
I am trying to run default Android OS that was on microSD with the kit and I tried the following commands (found them in OLED1 manual):
U-Boot > setenv fdt_file dtbo-imx8mm-mipi-panel.img
U-Boot > run bootcmd
But it won't change anything.
You'll need to reflash one of our android releases, you may find them here:
https://www.nxp.com/design/i.mx-developer-resources/i.mx-software-and-development-tools:IMX-SW
Please follow the guide Android_Quick_Start_Guide.pdf, I'll attach here the android_p9.0.0_2.0.0-ga one here, you'll find an step by step on how to flash the demo image in section 3.3 Flashing board images.
Hope this helps,
Aldo.
