MX7D ddr stress test fail
ソリューションへジャンプ
1,060件の閲覧回数
llliu
I use this tool to test MX7D.The calibration can be tested success.But when I click the stress test,it will report error.
How I can solve this problem.Is it due to a mistake in my .ds file?
ラベル(2)
タグ(1)
964件の閲覧回数
Yuri
  Check carefully memory parameters settings in the init (.ds) script.
Results of calibration should be inserted in the script.
Yuri
Note: If this post answers your question, please click the Correct Answer
button. Thank you!
965件の閲覧回数
Yuri
Yuri
button. Thank you!
