MX28: Build Manufacturing Firmware -blog archive
1,467件の閲覧回数
PeterChan
1. Install the LTIB environment to a new directory
2. In the new ltib directory, type this command to configure the build profile
    ./ltib -m selectype
3, Choose "imx_28" as platform type and "mfg firmware profile" as packages profile
4. Type this command to build updater.sb and updater_ivb.sb
    ./ltib
The above steps can also be found in i.MX28_Linux_BSP_UserGuide.pdf.
タグ(1)
0 返答(返信)
