MX1 bare-metal example code
755 次查看
samcheck
I need to resurrect UART 2 on the MC9328MX1
All the code supporting that UART was removed and a couple years later all the code was migrated from one version control system to another.
I know the odds are pretty long for efficiently bringing up a peripheral with only the manual for help.  Do you know of a bare-metal example that uses UART 2 without just using an OS’s drivers that I don’t have?
662 次查看
Hi Samuel
please look at attached file.
663 次查看
Hi Samuel
662 次查看
samcheck
Thank you!
