in datasheet "Table 10. Start-up Configuration" show a "default configuration"
MMPF0100NPEP is not programmed. Is "Default Configuration" the MMPF0100NPEP version?
I bought MMPF0100F0EP for a first test. Now i woud like to change the configuration.
Can i programm F0 version to customer version with programmer KITPFPGMEVME ?
Or means "pre-programmed" the final version?
"Pre-programmed OTP Configuration" means not "hard-coded configuration"
