MMFP0100 uses as PMIC for Hi3530a
lukegu
Dear ,
      As we know , the MMPF0100 is designed for the I.MX Series CPU. However , one of my customer want to plan use this PMIC for Hisilicon‘s platform Hi3530A as the system power controller . Would you kindly help me to check and confirm this application will be OK OR NOT? Thanks a lot !
art
Generally, MMPF0100 is very flexibly configurable general-purpose PMIC, designed for use as the part state-of-the-art MPU platforms, so it seems to be easily possible to use it for the MPUs other than i.MX series. Most likely, a custom OTP configuration will be required for that.
Artur
