Hi all,
I'd like to do DDR3 calibration with i.MX6DL.
Now I'm using MX6DL_SabreSD_DDR3_register_programming_aid_v2.2.xlsx.
DDR3 IC itself supports DDR3L-1866, but i.MX6DL supports DDR3-800.
So I have to check the DDR3-800 timing parameter from DDR3 IC's datasheet and set to MMDC timing parameter(DDR device timing parameter) of Register configuration such as tCKE, tRP, tCWL, ...
It's not DDR3L-1866's parameter.
Is my understanding correct?
Thanks in advance!
已解决! 转到解答。
