MJPEG : i.MX8mm
MJPEG : i.MX8mm
Siddharth
For our custom application, we want to use the MJPEG stream over RTSP on imx8mm.
But I check in the reference manual of imx8mm and it is mentioned that
"The driver supports JPEG images encoding and decoding through GStreamer, but it does not yet support MJPEG videos."
Can you please suggest using MJPEG streaming using GStreamer on imx8mm(the H/W plugin is preferable)?
Siddharth Singh
Hi Siddharth
one can look on (i.MX8M Mini vpu does not support mjpeg) :
https://variwiki.com/index.php?title=DART-MX8M_GSTREAMER
