MIPI OV5642 camera
MIPI OV5642 camera
1,509 次查看
yaşarcani_tişge
Hi ,
I am trying to use OV5642 in custom iMX6 board? Firstly,I just want to get the camera images in memory and save them . What should I do ?
Thanks.
标签 (3)
1 回复
1,347 次查看
JayTu
What's the OS you are using? If you are using linux-like, you'll need to use v4l2 API to dequeue a buffer.
There is the unit test, called mxc_v4l2_capture.c with v4l2 can do that.
