I want to use HDMI for my IMX8M Mini custom board.
I have consulted NXP's IMX-MIPI-HDMI board, but I cannot buy MIPI / HDMI converter IC ADV7535
so can i replace it with another IC?
Thank you
Solved! Go to Solution.
We do not recommend that. Since all of our designs and drivers are working with that device. You will need to implement a whole new configuration with the new device. I suggest you contact "Analog Devices" to see how you could get the IC.
Diego.
Diego.
Thank you for your reply.
I understand that
