MIPI Gasket, IPU, CSI and Device tree
2,736 次查看
davider
  I'm trying to write a DTS (Linux 3.10.17) for our custom designed board. I need to use all the 4 i.MX6D/Q CSI interfaces to acquire 4 MIPI streams on 4 virtual channels simultaneously.
  Is it possible using existent drivers and bindings, or does it require to extend their functionalities (or to write a new driver)?
标签 (2)
1,718 次查看
Hi Davide
yes this will require new drivers, also it may be useful
to check below discussion. Existent drivers and bindings
support only i.MX6 Sabre reference board configuration (one MIPI and one CSI parallel camera)
4 video capture using MIPI-CSI2 port
1,719 次查看
Hi Davide
1,718 次查看
davider
Ok, thank you.
You have confimed my fears... Even if it does not seems that difficult to extend the whole stuff, it will nonetheless be quite time consuming.
