MIPI CSI2 Camera Escape Clock
552 次查看
Cococarbine
I am working with the i.mx RT1160 processor, and in MCUXpresso when adding a Camera middleware component, the THS_SETTLE field will not accept any values above 255 (picture attached).  What can I do to fix this?
545 次查看
jingpan
Hi @Cococarbine ,
Yes, this field can only accept data less than 256. It seens like a bug. I'll report this problem. But you can only manually modify source code by now.
Jing
