MIMXRT1060-EVK backlight control
2,556 次查看
mspenard603
Is there demo code to control the LCD backlight on the IMXRT1060-EVK?
4 回复数
1,140 次查看
ToNato
Hi NXP,
I'm using RT1060 for our product. I am also having issues with GPIO_B1_15 to generate PWM for backlight. I have some questions.
1- What XBARA is used with GPIO_B1_15_FLEXPWM4_PWMA03? 1, 2, 3?
2- Can you write for us a simple code to configure for properly? I'm trying one day but I cannot configure successfully although, the SDK example is working well on board.
2,398 次查看
jingpan
There is no direct backlight demo. In all lcd demo, GPIO_B1_15 works as gpio. In backlight circuit, UM1661 support PWM dimming control. Please refer to the PWM demo in SDK.
Jing
2,398 次查看
mspenard603
Hi Jing,
 Thanks, started to look at the PWM demo. The backlight on GPIO_B1_15 is PWM4_PWMA03. Trying to figure out how to plumb that. I have the following but I'm not seeing anything on my scope.
* Copyright (c) 2015, Freescale Semiconductor, Inc.
* Copyright 2016-2017 NXP
* All rights reserved.
* SPDX-License-Identifier: BSD-3-Clause
#include "fsl_debug_console.h"
#include "board.h"
#include "fsl_pwm.h"
#include "pin_mux.h"
#include "fsl_xbara.h"
* Definitions
/* The PWM base address */
#define BOARD_PWM_BASEADDR PWM4 //PWM1 mls
#define PWM_SRC_CLK_FREQ CLOCK_GetFreq(kCLOCK_IpgClk)
* Prototypes
* Variables
* Code
static void PWM_DRV_Init3PhPwm(void)
uint16_t deadTimeVal;
pwm_signal_param_t pwmSignal[2];
uint32_t pwmSourceClockInHz;
uint32_t pwmFrequencyInHz = 1000;
pwmSourceClockInHz = PWM_SRC_CLK_FREQ;
/* Set deadtime count, we set this to about 650ns */
deadTimeVal = ((uint64_t)pwmSourceClockInHz * 650) / 1000000000;
pwmSignal[0].pwmChannel = kPWM_PwmA;
pwmSignal[0].level = kPWM_HighTrue;
pwmSignal[0].dutyCyclePercent = 50; /* 1 percent dutycycle */
pwmSignal[0].deadtimeValue = deadTimeVal;
pwmSignal[1].pwmChannel = kPWM_PwmB;
pwmSignal[1].level = kPWM_HighTrue;
/* Dutycycle field of PWM B does not matter as we are running in PWM A complementary mode */
pwmSignal[1].dutyCyclePercent = 50;
pwmSignal[1].deadtimeValue = deadTimeVal;
/*********** PWMA_SM0 - phase A, configuration, setup 2 channel as an example ************/
PWM_SetupPwm(BOARD_PWM_BASEADDR, kPWM_Module_0, pwmSignal, 2, kPWM_SignedCenterAligned, pwmFrequencyInHz,
pwmSourceClockInHz);
/*********** PWMA_SM1 - phase B configuration, setup PWM A channel only ************/
PWM_SetupPwm(BOARD_PWM_BASEADDR, kPWM_Module_1, pwmSignal, 1, kPWM_SignedCenterAligned, pwmFrequencyInHz,
/*********** PWMA_SM2 - phase C configuration, setup PWM A channel only ************/
PWM_SetupPwm(BOARD_PWM_BASEADDR, kPWM_Module_2, pwmSignal, 1, kPWM_SignedCenterAligned, pwmFrequencyInHz,
/*********** PWMA_SM3 - phase C configuration, setup PWM A channel only ************/
PWM_SetupPwm(BOARD_PWM_BASEADDR, kPWM_Module_3, pwmSignal, 1, kPWM_SignedCenterAligned, pwmFrequencyInHz,
* @brief Main function
int main(void)
/* Structure of initialize PWM */
pwm_config_t pwmConfig;
static uint16_t delay;
uint32_t pwmVal = 4;
uint16_t i;
/* Board pin, clock, debug console init */
BOARD_ConfigMPU();
BOARD_InitPins();
BOARD_BootClockRUN();
BOARD_InitDebugConsole();
CLOCK_SetDiv(kCLOCK_AhbDiv, 0x2); /* Set AHB PODF to 2, divide by 3 */
CLOCK_SetDiv(kCLOCK_IpgDiv, 0x3); /* Set IPG PODF to 3, divede by 4 */
/* Set the PWM Fault inputs to a low value */
XBARA_Init(XBARA1);
XBARA_SetSignalsConnection(XBARA1, kXBARA1_InputLogicHigh, kXBARA1_OutputFlexpwm1Fault0);
XBARA_SetSignalsConnection(XBARA1, kXBARA1_InputLogicHigh, kXBARA1_OutputFlexpwm1Fault1);
XBARA_SetSignalsConnection(XBARA1, kXBARA1_InputLogicHigh, kXBARA1_OutputFlexpwm1234Fault2);
XBARA_SetSignalsConnection(XBARA1, kXBARA1_InputLogicHigh, kXBARA1_OutputFlexpwm1234Fault3);
PRINTF("FlexPWM driver example\n");
* pwmConfig.enableDebugMode = false;
* pwmConfig.enableWait = false;
* pwmConfig.reloadSelect = kPWM_LocalReload;
* pwmConfig.faultFilterCount = 0;
* pwmConfig.faultFilterPeriod = 0;
* pwmConfig.clockSource = kPWM_BusClock;
* pwmConfig.prescale = kPWM_Prescale_Divide_1;
* pwmConfig.initializationControl = kPWM_Initialize_LocalSync;
* pwmConfig.forceTrigger = kPWM_Force_Local;
* pwmConfig.reloadFrequency = kPWM_LoadEveryOportunity;
* pwmConfig.reloadLogic = kPWM_ReloadImmediate;
* pwmConfig.pairOperation = kPWM_Independent;
PWM_GetDefaultConfig(&pwmConfig);
/* Use full cycle reload */
pwmConfig.reloadLogic = kPWM_ReloadPwmFullCycle;
/* PWM A & PWM B form a complementary PWM pair */
pwmConfig.pairOperation = kPWM_ComplementaryPwmA;
pwmConfig.enableDebugMode = true;
/* Initialize submodule 0 */
if (PWM_Init(BOARD_PWM_BASEADDR, kPWM_Module_0, &pwmConfig) == kStatus_Fail)
PRINTF("PWM initialization failed\n");
return 1;
/* Initialize submodule 1 */
pwmConfig.clockSource = kPWM_Submodule0Clock;
pwmConfig.initializationControl = kPWM_Initialize_MasterSync;
if (PWM_Init(BOARD_PWM_BASEADDR, kPWM_Module_1, &pwmConfig) == kStatus_Fail)
return 1;
/* Initialize submodule 2 the same way as submodule 1 */
if (PWM_Init(BOARD_PWM_BASEADDR, kPWM_Module_2, &pwmConfig) == kStatus_Fail)
return 1;
/* Initialize submodule 3 the same way as submodule 1 */
if (PWM_Init(BOARD_PWM_BASEADDR, kPWM_Module_3, &pwmConfig) == kStatus_Fail)
return 1;
/* Call the init function with demo configuration */
PWM_DRV_Init3PhPwm();
/* Set the load okay bit for all submodules to load registers from their buffer */
PWM_SetPwmLdok(BOARD_PWM_BASEADDR, kPWM_Control_Module_0 | kPWM_Control_Module_1 | kPWM_Control_Module_2 | kPWM_Control_Module_3, true);
/* Start the PWM generation from Submodules 0, 1 and 2 */
PWM_StartTimer(BOARD_PWM_BASEADDR, kPWM_Control_Module_0 | kPWM_Control_Module_1 | kPWM_Control_Module_2 | kPWM_Control_Module_3);
delay = 0x0fffU;
while (1U)
for (i = 0U; i < delay; i++)
__ASM volatile("nop");
pwmVal = pwmVal + 4;
/* Reset the duty cycle percentage */
if (pwmVal > 100)
pwmVal = 4;
/* Update duty cycles for all 3 PWM signals */
PWM_UpdatePwmDutycycle(BOARD_PWM_BASEADDR, kPWM_Module_0, kPWM_PwmA, kPWM_SignedCenterAligned, pwmVal);
PWM_UpdatePwmDutycycle(BOARD_PWM_BASEADDR, kPWM_Module_1, kPWM_PwmA, kPWM_SignedCenterAligned, (pwmVal >> 1));
PWM_UpdatePwmDutycycle(BOARD_PWM_BASEADDR, kPWM_Module_2, kPWM_PwmA, kPWM_SignedCenterAligned, (pwmVal >> 2));
PWM_UpdatePwmDutycycle(BOARD_PWM_BASEADDR, kPWM_Module_3, kPWM_PwmA, kPWM_SignedCenterAligned, (pwmVal >> 3));
2,398 次查看
jingpan
have you change the pin configuration in BOARD_InitPins()?
Jing
%3CLINGO-SUB%20id%3D%22lingo-sub-998321%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EMIMXRT1060-EVK%20%E8%83%8C%E5%85%89%E6%8E%A7%E5%88%B6%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-998321%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%9C%89%E6%8E%A7%E5%88%B6%20IMXRT1060-EVK%20%E7%9A%84%20LCD%20%E8%83%8C%E5%85%89%E7%9A%84%E6%BC%94%E7%A4%BA%E4%BB%A3%E7%A0%81%E5%90%97%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2166177%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MIMXRT1060-EVK%20backlight%20control%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2166177%22%20slang%3D%22en-US%22%20mode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id%3D%22lingo-sub-998324%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MIMXRT1060-EVK%20backlight%20control%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-998324%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%82%A8%E5%A5%BD%EF%BC%8C%3C%2FP%3E%3CP%3E%E6%82%A8%E6%98%AF%E5%90%A6%E5%9C%A8%20BOARD_InitPins()%20%E4%B8%AD%E6%9B%B4%E6%94%B9%E4%BA%86%E5%BC%95%E8%84%9A%E9%85%8D%E7%BD%AE%EF%BC%9F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%AD%A4%E8%87%B4%EF%BC%8C%3C%2FP%3E%3CP%3E%E6%99%AF%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-998323%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MIMXRT1060-EVK%20backlight%20control%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-998323%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E5%97%A8%EF%BC%8CJing%E3%80%81%3C%2FP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CP%3E%E8%B0%A2%E8%B0%A2%EF%BC%8C%E6%88%91%E5%B7%B2%E7%BB%8F%E5%BC%80%E5%A7%8B%E7%9C%8B%20PWM%20%E6%BC%94%E7%A4%BA%E4%BA%86%E3%80%82GPIO_B1_15%20%E4%B8%8A%E7%9A%84%E8%83%8C%E5%85%89%E4%B8%BA%20PWM4_PWMA03%E3%80%82%E6%AD%A3%E5%9C%A8%E6%83%B3%E5%8A%9E%E6%B3%95%E8%A7%A3%E5%86%B3%E8%BF%99%E4%B8%AA%E9%97%AE%E9%A2%98%E3%80%82%E6%88%91%E6%9C%89%E4%BB%A5%E4%B8%8B%E8%AE%BE%E5%A4%87%EF%BC%8C%E4%BD%86%E5%9C%A8%E7%9E%84%E5%87%86%E9%95%9C%E4%B8%8A%E7%9C%8B%E4%B8%8D%E5%88%B0%E4%BB%BB%E4%BD%95%E4%B8%9C%E8%A5%BF%E3%80%82%3C%2FP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CP%3E%3C%2FP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CP%3E%3C%2FP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CP%3E%3C%2FP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CP%3E%2F%3CBR%20%2F%3E*%20%E7%89%88%E6%9D%83%E6%89%80%E6%9C%89%20(c)%202015%20%E5%B9%B4%EF%BC%8C%E9%A3%9E%E6%80%9D%E5%8D%A1%E5%B0%94%E5%8D%8A%E5%AF%BC%E4%BD%93%E6%9C%89%E9%99%90%E5%85%AC%E5%8F%B8%20*%202016-2017%20%E5%B9%B4%E6%81%A9%E6%99%BA%E6%B5%A6%3CBR%20%2F%3E%E7%89%88%E6%9D%83%E6%89%80%E6%9C%89%20%3CBR%20%2F%3E%20*%20%E7%89%88%E6%9D%83%E6%89%80%E6%9C%89%E3%80%82%3CBR%20%2F%3E*%3CBR%20%2F%3E%20*%20SPDX-License-Identifier%EF%BC%9ABSD-3-Clause%3CBR%20%2F%3E%20*%2F%3C%2FP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CP%3E%23include%20%22fsl_debug_console.h%22%3CBR%20%2F%3E%23include%20%22%E6%9D%BF.h%22%3CBR%20%2F%3E%23include%22fsl_pwm.h%22%3C%2FP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CP%3E%23include%22pin_mux.h%22%3CBR%20%2F%3E%23include%22fsl_xbara.h%22%3CBR%20%2F%3E%2F*******************************************************************************%3CBR%20%2F%3E%20*%20%E5%AE%9A%E4%B9%89%3CBR%20%2F%3E%20******************************************************************************%2F%3CBR%20%2F%3E%2F*%20PWM%20%E5%9F%BA%E5%9C%B0%E5%9D%80%20*%2F%3CBR%20%2F%3E%23define%20BOARD_PWM_BASEADDR%20PWM4%20%2F%2FPWM1%20mls%3C%2FP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CP%3E%23define%20PWM_SRC_CLK_FREQ%20CLOCK_GetFreq(kCLOCK_IpgClk)%3C%2FP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CP%3E%2F*******************************************************************************%3CBR%20%2F%3E%20*%20Prototypes%3CBR%20%2F%3E%20******************************************************************************%2F%3C%2FP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CP%3E%2F*******************************************************************************%3CBR%20%2F%3E%20*%20Variables%3CBR%20%2F%3E%20******************************************************************************%2F%3C%2FP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CP%3E%2F*******************************************************************************%3CBR%20%2F%3E%20*%20%E4%BB%A3%E7%A0%81%3CBR%20%2F%3E%20******************************************************************************%2F%3CBR%20%2F%3Estatic%20void%20PWM_DRV_Init3PhPwm(void)%3CBR%20%2F%3E%7B%3CBR%20%2F%3E%20uint16_t%20deadTimeVal%3B%3CBR%20%2F%3E%20pwm_signal_param_t%20pwmSignal%5B2%5D%3B%3CBR%20%2F%3E%20uint32_t%20pwmSourceClockInHz%3B%3CBR%20%2F%3E%20uint32_t%20pwmFrequencyInHz%20%3D%201000%EF%BC%9B%3C%2FP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CP%3EpwmSourceClockInHz%20%3D%20PWM_SRC_CLK_FREQ%EF%BC%9B%3C%2FP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CP%3E%2F*%20%E8%AE%BE%E7%BD%AE%E6%AD%BB%E5%8C%BA%E6%97%B6%E9%97%B4%E8%AE%A1%E6%95%B0%EF%BC%8C%E6%88%91%E4%BB%AC%E5%B0%86%E5%85%B6%E8%AE%BE%E7%BD%AE%E4%B8%BA%E7%BA%A6%20650ns%20*%2F%3CBR%20%2F%3E%20deadTimeVal%20%3D%20((uint64_t)pwmSourceClockInHz%20*%20650)%20%2F%201000000000%EF%BC%9B%3C%2FP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CP%3EpwmSignal%5B0%5D.pwmChannel%3D%20kPWM_PwmA%3B%3CBR%20%2F%3E%20pwmSignal%5B0%5D.level%3D%20kPWM_HighTrue%3B%3CBR%20%2F%3E%20pwmSignal%5B0%5D.dutyCyclePercent%3D%2050%3B%20%2F*%201%25%20%E5%8D%A0%E7%A9%BA%E6%AF%94%20*%2F%3CBR%20%2F%3E%20pwmSignal%5B0%5D.deadtimeValue%3D%20deadTimeVal%EF%BC%9B%3C%2FP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CP%3EpwmSignal%5B1%5D.pwmChannel%3D%20kPWM_PwmB%3B%3CBR%20%2F%3E%20pwmSignal%5B1%5D.level%3D%20kPWM_HighTrue%3B%3CBR%20%2F%3E%20%2F*%20PWM%20B%20%E7%9A%84%E5%8D%A0%E7%A9%BA%E6%AF%94%E5%AD%97%E6%AE%B5%E5%B9%B6%E4%B8%8D%E9%87%8D%E8%A6%81%EF%BC%8C%E5%9B%A0%E4%B8%BA%E6%88%91%E4%BB%AC%E6%98%AF%E5%9C%A8%20PWM%20A%20%E4%BA%92%E8%A1%A5%E6%A8%A1%E5%BC%8F%E4%B8%8B%E8%BF%90%E8%A1%8C%20*%2F%3CBR%20%2F%3E%20pwmSignal%5B1%5D.dutyCyclePercent%3D%2050%3B%3CBR%20%2F%3E%20pwmSignal%5B1%5D.deadtimeValue%3D%20deadTimeVal%EF%BC%9B%3C%2FP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CP%3E%2F***********%20PWMA_SM0%20-%20A%20%E7%9B%B8%EF%BC%8C%E9%85%8D%E7%BD%AE%EF%BC%8C%E8%AE%BE%E7%BD%AE%202%20%E9%80%9A%E9%81%93%E4%B8%BA%E4%BE%8B%20************%2F%3CBR%20%2F%3E%20PWM_SetupPwm(BOARD_PWM_BASEADDR%2C%20kPWM_Module_0%2C%20pwmSignal%2C%202%2C%20kPWM_SignedCenterAligned%2C%20pwmFrequencyInHz%2C%3CBR%20%2F%3E%20pwmSourceClockInHz)%EF%BC%9B%3C%2FP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CP%3E%2F***********%20PWMA_SM1%20-%20B%20%E7%9B%B8%E9%85%8D%E7%BD%AE%EF%BC%8C%E4%BB%85%E8%AE%BE%E7%BD%AE%20PWM%20A%20%E9%80%9A%E9%81%93%20************%2F%3CBR%20%2F%3E%20PWM_SetupPwm(BOARD_PWM_BASEADDR%EF%BC%8CkPWM_Module_1%EF%BC%8CpwmSignal%EF%BC%8C1%EF%BC%8CkPWM_SignedCenterAligned%EF%BC%8CpwmFrequencyInHz%EF%BC%8C%3CBR%20%2F%3E%20pwmSourceClockInHz)%EF%BC%9B%3C%2FP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CP%3E%2F***********%20PWMA_SM2%20-%20C%20%E7%9B%B8%E9%85%8D%E7%BD%AE%EF%BC%8C%E4%BB%85%E8%AE%BE%E7%BD%AE%20PWM%20A%20%E9%80%9A%E9%81%93%20************%2F%3CBR%20%2F%3E%20PWM_SetupPwm(BOARD_PWM_BASEADDR%EF%BC%8CkPWM_Module_2%EF%BC%8CpwmSignal%EF%BC%8C1%EF%BC%8CkPWM_SignedCenterAligned%EF%BC%8CpwmFrequencyInHz%EF%BC%8C%3CBR%20%2F%3E%20pwmSourceClockInHz)%EF%BC%9B%3C%2FP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CP%3E%2F***********%20PWMA_SM3%20-%20C%20%E7%9B%B8%E9%85%8D%E7%BD%AE%EF%BC%8C%E4%BB%85%E8%AE%BE%E7%BD%AE%20PWM%20A%20%E9%80%9A%E9%81%93%20************%2F%3CBR%20%2F%3E%20PWM_SetupPwm(BOARD_PWM_BASEADDR%EF%BC%8CkPWM_Module_3%EF%BC%8CpwmSignal%EF%BC%8C1%EF%BC%8CkPWM_SignedCenterAligned%EF%BC%8CpwmFrequencyInHz%EF%BC%8C%3CBR%20%2F%3E%20pwmSourceClockInHz)%EF%BC%9B%3C%2FP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CP%3E%3C%2FP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CP%3E%3CBR%20%2F%3E%7D%3C%2FP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CP%3E%2F*!%3CBR%20%2F%3E%20*%20%40brief%20Main%20function%3CBR%20%2F%3E%20*%2F%3CBR%20%2F%3Eint%20main(void)%3CBR%20%2F%3E%7B%3CBR%20%2F%3E%20%2F*%20%E5%88%9D%E5%A7%8B%E5%8C%96%20PWM%20%E7%9A%84%E7%BB%93%E6%9E%84%20*%2F%3CBR%20%2F%3E%20pwm_config_t%20pwmConfig%3B%3CBR%20%2F%3E%20static%20uint16_t%20delay%3B%3CBR%20%2F%3E%20uint32_t%20pwmVal%20%3D%204%3B%3CBR%20%2F%3E%20uint16_t%20i%EF%BC%9B%3C%2FP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CP%3E%2F*%20%E6%9D%BF%E5%BC%95%E8%84%9A%E3%80%81%E6%97%B6%E9%92%9F%E3%80%81%E8%B0%83%E8%AF%95%E6%8E%A7%E5%88%B6%E5%8F%B0%E5%88%9D%E5%A7%8B%E5%8C%96%20*%2F%20%3CBR%20%2F%3E%20board_configmpu%20()%3B%20board_initPins%20()%3B%20board_bootclockRun%20()%3B%20%3CBR%20%2F%3E%20board_bootclockRun%20()%3B%20board_initDebugCon%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%3C%2FP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CP%3ECLOCK_SetDiv(kCLOCK_AhbDiv%2C%200x2)%3B%20%2F*%20%E5%B0%86%20AHB%20PODF%20%E8%AE%BE%E7%BD%AE%E4%B8%BA%202%EF%BC%8C%E9%99%A4%E4%BB%A5%203%20*%2F%3CBR%20%2F%3E%20CLOCK_SetDiv(kCLOCK_IpgDiv%2C%200x3)%3B%20%2F*%20%E5%B0%86%20IPG%20PODF%20%E8%AE%BE%E7%BD%AE%E4%B8%BA%203%EF%BC%8C%E9%99%A4%E4%BB%A5%204%20*%2F%3C%2FP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CP%3E%2F*%20%E5%B0%86%20PWM%20%E6%95%85%E9%9A%9C%E8%BE%93%E5%85%A5%E8%AE%BE%E7%BD%AE%E4%B8%BA%E4%BD%8E%E5%80%BC%20*%2F%3CBR%20%2F%3E%20XBARA_Init(XBARA1)%EF%BC%9B%3CBR%20%2F%3E%20XBARA_SetSignalsConnection(XBARA1%EF%BC%8CkXBARA1_InputLogicHigh%EF%BC%8CkXBARA1_OutputFlexpwm1Fault0)%EF%BC%9B%3CBR%20%2F%3E%20XBARA_SetSignalsConnection(XBARA1%2C%20kXBARA1_InputLogicHigh%2C%20kXBARA1_OutputFlexpwm1Fault1)%EF%BC%9B%3CBR%20%2F%3E%20XBARA_SetSignalsConnection(XBARA1%2C%20kXBARA1_InputLogicHigh%2C%20kXBARA1_OutputFlexpwm1234Fault2)%3B%3CBR%20%2F%3E%20XBARA_SetSignalsConnection(XBARA1%2C%20kXBARA1_InputLogicHigh%2C%20kXBARA1_OutputFlexpwm1234Fault3)%EF%BC%9B%3C%2FP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CP%3EPRINTF(%22FlexPWM%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%20example%5Cn%22)%EF%BC%9B%3C%2FP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CP%3E%2F*%3CBR%20%2F%3E%20*%20pwmConfig.enableDebugMode%3D%20false%3B%3CBR%20%2F%3E%20*%20pwmConfig.enableWait%20%3D%20false%3B%3CBR%20%2F%3E%20*%20pwmConfig.reloadSelect%3D%20kPWM_LocalReload%3B%3CBR%20%2F%3E%20*%20pwmConfig.faultFilterCount%3D%200%3B%3CBR%20%2F%3E%20*%20pwmConfig.faultFilterPeriod%3D%200%3B%3CBR%20%2F%3E%20*%20pwmConfig.clockSource%20%3D%20kPWM_BusClock%EF%BC%9B%3CBR%20%2F%3E%20*%20pwmConfig.prescale%20%3D%20kPWM_Prescale_Divide_1%EF%BC%9B%3CBR%20%2F%3E%20*%20pwmConfig.initializationControl%3D%20kPWM_Initialize_LocalSync%3B%3CBR%20%2F%3E%20*%20pwmConfig.forceTrigger%3D%20kPWM_Force_Local%3B%3CBR%20%2F%3E%20*%20pwmConfig.reloadFrequency%3D%20kPWM_LoadEveryOportunity%3B%3CBR%20%2F%3E%20*%20pwmConfig.reloadLogic%20%3D%20kPWM_ReloadImmediate%3B%3CBR%20%2F%3E%20*%20pwmConfig.pairOperation%3D%20kPWM_Independent%3B%3CBR%20%2F%3E%20*%2F%3CBR%20%2F%3E%20PWM_GetDefaultConfig(%26amp%3BpwmConfig)%EF%BC%9B%3C%2FP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CP%3E%2F*%20%E4%BD%BF%E7%94%A8%E5%85%A8%E5%91%A8%E6%9C%9F%E9%87%8D%E8%BD%BD%20*%2F%3CBR%20%2F%3E%20pwmConfig.reloadLogic%20%3D%20kPWM_ReloadPwmFullCycle%3B%3CBR%20%2F%3E%20%2F*%20PWM%20A%26amp%3B%20PWM%20B%20%E5%BD%A2%E6%88%90%E4%B8%80%E5%AF%B9%E4%BA%92%E8%A1%A5%20PWM%20*%2F%3CBR%20%2F%3E%20pwmConfig.pairOperation%3D%20kPWM_ComplementaryPwmA%3B%3CBR%20%2F%3E%20pwmConfig.enableDebugMode%3D%20true%EF%BC%9B%3C%2FP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CP%3E%2F*%20%E5%88%9D%E5%A7%8B%E5%8C%96%E5%AD%90%E6%A8%A1%E5%9D%97%200%20*%2F%3CBR%20%2F%3E%20if%20(PWM_Init(BOARD_PWM_BASEADDR%2C%20kPWM_Module_0%2C%26amp%3BpwmConfig)%20%3D%3D%20kStatus_Fail)%3CBR%20%2F%3E%20%7B%3CBR%20%2F%3E%20PRINTF(%22PWM%20%E5%88%9D%E5%A7%8B%E5%8C%96%E5%A4%B1%E8%B4%A5%2Fn%22)%3B%3CBR%20%2F%3E%20return%201%3B%3CBR%20%2F%3E%20%7D%3C%2FP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CP%3E%2F*%20%E5%88%9D%E5%A7%8B%E5%8C%96%E5%AD%90%E6%A8%A1%E5%9D%97%201%20*%2F%3CBR%20%2F%3E%20pwmConfig.clockSource%20%3D%20kPWM_Submodule0Clock%EF%BC%9B%3CBR%20%2F%3E%20pwmConfig.initializationControl%3D%20kPWM_Initialize_MasterSync%3B%3CBR%20%2F%3E%20if%20(PWM_Init(BOARD_PWM_BASEADDR%2C%20kPWM_Module_1%2C%26amp%3BpwmConfig)%20%3D%3D%20kStatus_Fail)%3CBR%20%2F%3E%20%7B%3CBR%20%2F%3E%20PRINTF(%22PWM%20%E5%88%9D%E5%A7%8B%E5%8C%96%E5%A4%B1%E8%B4%A5%22)%3B%3CBR%20%2F%3E%20return%201%3B%3CBR%20%2F%3E%20%7D%3C%2FP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CP%3E%2F*%20%E5%AD%90%E6%A8%A1%E5%9D%97%202%20%E7%9A%84%E5%88%9D%E5%A7%8B%E5%8C%96%E6%96%B9%E6%B3%95%E4%B8%8E%E5%AD%90%E6%A8%A1%E5%9D%97%201%20%E7%9B%B8%E5%90%8C%20*%2F%3CBR%20%2F%3E%20if%20(PWM_Init(BOARD_PWM_BASEADDR%2C%20kPWM_Module_2%2C%26amp%3BpwmConfig)%20%3D%3D%20kStatus_Fail)%3CBR%20%2F%3E%20%7B%3CBR%20%2F%3E%20PRINTF(%22PWM%20%E5%88%9D%E5%A7%8B%E5%8C%96%E5%A4%B1%E8%B4%A5%2Fn%22)%3B%3CBR%20%2F%3E%20return%201%3B%3CBR%20%2F%3E%20%7D%3C%2FP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CP%3E%2F*%20%E5%AD%90%E6%A8%A1%E5%9D%97%203%20%E7%9A%84%E5%88%9D%E5%A7%8B%E5%8C%96%E6%96%B9%E6%B3%95%E4%B8%8E%E5%AD%90%E6%A8%A1%E5%9D%97%201%20%E7%9B%B8%E5%90%8C%20*%2F%3CBR%20%2F%3E%20if%20(PWM_Init(BOARD_PWM_BASEADDR%2C%20kPWM_Module_3%2C%26amp%3BpwmConfig)%20%3D%3D%20kStatus_Fail)%3CBR%20%2F%3E%20%7B%3CBR%20%2F%3E%20PRINTF(%22PWM%20%E5%88%9D%E5%A7%8B%E5%8C%96%E5%A4%B1%E8%B4%A5%2Fn%22)%3B%3CBR%20%2F%3E%20return%201%3B%3CBR%20%2F%3E%20%7D%3C%2FP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CP%3E%3CBR%20%2F%3E%20%2F*%20%E4%BD%BF%E7%94%A8%E6%BC%94%E7%A4%BA%E9%85%8D%E7%BD%AE%E8%B0%83%E7%94%A8%E5%88%9D%E5%A7%8B%E5%87%BD%E6%95%B0%20*%2F%3CBR%20%2F%3E%20PWM_DRV_Init3PhPwm()%EF%BC%9B%3C%2FP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CP%3E*%2F%3CBR%20%2F%3E%20PWM_SetPwmLdok(BOARD_PWM_BASEADDR%2C%20kPWM_Control_Module_0%20%7C%20kPWM_Control_Module_1%20%7C%20kPWM_Control_Module_2%20%7C%20kPWM_Control_Module_3%2C%20true)%EF%BC%9B%3C%2FP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CP%3E%2F*%20%E4%BB%8E%E5%AD%90%E6%A8%A1%E5%9D%97%200%E3%80%811%20%E5%92%8C%202%20%E5%BC%80%E5%A7%8B%E4%BA%A7%E7%94%9F%20PWM%20*%2F%3CBR%20%2F%3E%20PWM_StartTimer(BOARD_PWM_BASEADDR%EF%BC%8CkPWM_Control_Module_0%20%7C%20kPWM_Control_Module_1%20%7C%20kPWM_Control_Module_2%20%7C%20kPWM_Control_Module_3)%EF%BC%9B%3C%2FP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CP%3E%E5%BB%B6%E8%BF%9F%20%3D%200x0fffU%EF%BC%9B%3C%2FP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CP%3Ewhile%20(1U)%3CBR%20%2F%3E%20%7B%3CBR%20%2F%3E%20for%20(i%20%3D%200U%3B%20i%26lt%3B%20delay%3B%20i%2B%2B)%3CBR%20%2F%3E%20%7B%3CBR%20%2F%3E%20__ASM%20volatile(%22nop%22)%3B%3CBR%20%2F%3E%20%7D%3CBR%20%2F%3E%20pwmVal%20%3D%20pwmVal%20%2B%204%EF%BC%9B%3C%2FP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CP%3E%2F*%20RESET%20%E5%8D%A0%E7%A9%BA%E6%AF%94%E7%99%BE%E5%88%86%E6%AF%94%20*%2F%3CBR%20%2F%3E%20if%20(pwmVal%20%26gt%3B%20100)%3CBR%20%2F%3E%20%7B%3CBR%20%2F%3E%20pwmVal%20%3D%204%3B%3CBR%20%2F%3E%20%7D%3C%2FP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CP%3E%2F*%20%E6%9B%B4%E6%96%B0%E6%89%80%E6%9C%89%203%20%E4%B8%AA%20PWM%20%E4%BF%A1%E5%8F%B7%E7%9A%84%E5%8D%A0%E7%A9%BA%E6%AF%94%20*%2F%20pwm_updatePWMDutycle%EF%BC%88BOARD_PWM_BASEADDR%E3%80%81KPWM_Mod%20%3CBR%20%2F%3E%20ule_0%E3%80%81KPWM_PWM_PWMA%E3%80%81KPWM_SignedCenterAligned%E3%80%81PWMVAL%EF%BC%89%EF%BC%9Bpwm_updatePWMDutycle%EF%BC%88BOARD_PWM_BASEADDR%E3%80%81KPWM_Module_1%E3%80%81KPWM_PWM_PWMA%EF%BC%8CKPWM_SignedCenterAligned%EF%BC%8C(pwmVal%20%26gt%3B%20%26gt%3B%201))%EF%BC%9Bpwm_updatePWMDutycle%EF%BC%88BOARD_PWM_BASEADDR%E3%80%81KPWM_Module_2%E3%80%81KPWM_PWMMA%E3%80%81KPWM_SignedCenterAligned%EF%BC%8C(pwmVal%20%26gt%3B%20%26gt%3B%202)%EF%BC%89%EF%BC%9B%3CBR%20%2F%3EPWM_updatePWMDutycle%20(%3CBR%20%2F%3E%3CBR%20%2F%3EBOARD_PWM_BASEADDR%E3%80%81KPWM_module_3%E3%80%81KPWM_PWMA%E3%80%81KPWM_SignedCenterAligned%EF%BC%8C(pwmVal%20%26gt%3B%20%26gt%3B%203))%EF%BC%9B%3C%2FP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CP%3E%2F*%20%E8%AE%BE%E7%BD%AE%E6%89%80%E6%9C%89%E5%AD%90%E6%A8%A1%E5%9D%97%E7%9A%84%E5%8A%A0%E8%BD%BD%E5%85%81%E8%AE%B8%E4%BD%8D%EF%BC%8C%E4%BB%A5%E4%BE%BF%E4%BB%8E%E5%85%B6%E7%BC%93%E5%86%B2%E5%8C%BA%E5%8A%A0%E8%BD%BD%E5%AF%84%E5%AD%98%E5%99%A8%20*%2F%3CBR%20%2F%3E%20PWM_SetPwmLdok(BOARD_PWM_BASEADDR%2C%20kPWM_Control_Module_0%20%7C%20kPWM_Control_Module_1%20%7C%20kPWM_Control_Module_2%20%7C%20kPWM_Control_Module_3%2C%20true)%3B%3CBR%20%2F%3E%20%7D%3CBR%20%2F%3E%7D%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-998322%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MIMXRT1060-EVK%20backlight%20control%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-998322%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%82%A8%E5%A5%BD%EF%BC%8C%3C%2FP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CP%3E%E6%B2%A1%E6%9C%89%E7%9B%B4%E6%8E%A5%E7%9A%84%E8%83%8C%E5%85%89%E6%BC%94%E7%A4%BA%E3%80%82%E5%9C%A8%E6%89%80%E6%9C%89%20LCD%20%E6%BC%94%E7%A4%BA%E4%B8%AD%EF%BC%8CGPIO_B1_15%20%E9%83%BD%E4%BD%9C%E4%B8%BA%20gpio%20%E5%B7%A5%E4%BD%9C%E3%80%82%E5%9C%A8%E8%83%8C%E5%85%89%E7%94%B5%E8%B7%AF%E4%B8%AD%EF%BC%8CUM1661%20%E6%94%AF%E6%8C%81%20PWM%20%E8%B0%83%E5%85%89%E6%8E%A7%E5%88%B6%E3%80%82%E8%AF%B7%E5%8F%82%E8%80%83%20SDK%20%E4%B8%AD%E7%9A%84%20PWM%20%E6%BC%94%E7%A4%BA%E3%80%82%3C%2FP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CP%3E%3C%2FP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CP%3E%E6%AD%A4%E8%87%B4%EF%BC%8C%3C%2FP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CP%3E%E6%99%AF%3C%2FP%3E%3C%2FLINGO-BODY%3E
