MFG烧录错误
MFG烧录错误
Harris
我在用MFGtools烧录SD卡时,在Formatting rootfs partition阶段出现错误。
开发板是IMX6Q-SDB
MFGTools Library 2.3.3 ,
cfg.ini 内容如下:
[profiles]
chip = Linux
[platform]
board = SabreSD
[LIST]
name = SDCard
[variable]
board = sabresd
mmc = 0
sxuboot=17x17arm2
sxdtb=17x17-arm2
ldo=
请帮忙分析下可能出错的地方,谢谢!
Hi Harris
you can try other card or create image on Host
using attached document sect.4.3 Preparing an SD/MMC card to boot
