MCUXpresso: usage of FLEXSPI_TransferNonBlocking API with iMX8QXP
已解决
跳至解决方案
1,275 次查看
pierluigi_p
Senior Contributor I
Hi all,
surfing MCUXpresso documentation and source code, in file
    devices/MIMX8QX6/drivers/fsl_flexspi.c
You can find the API
The notes recommend using the function
    FLEXSPI_GetTransferCount
in order to poll the transfer status, however this seems to be not available in MCUXpresso.
Is there any sample reference code showing how to actually use FLEXSPI_TransferNonBlocking API?
Pier
1 解答
1,262 次查看
AldoG
I'm afraid there is not, as you may know the only example we have available using FSPI in SDK is the Octal example which uses polling transfers.
Aldo.
在原帖中查看解决方案
1 回复
1,263 次查看
AldoG
Aldo.
