MCIMX6ULL-EVK - Not Working
philhale
Just unboxed i.MX6ULL evaluation board.
Followed the Quick Start Guide.
Board does not appear to be working. Nothing appears on serial interface (USB-CDC) and all lights on dual ethernet connectors stay illuminated. Possible short someplace(?)
Booting from SD Card (Linux). Dip switch settings match Quick Start Guide.
Anything else to try or shall I just return the board?
Phil
philhale
Replaced EVK. Everything seems to be working properly.
Phil
joanxie
maybe your SD card is broken, try to download the demo images to the SD card by dd command or UUU tool, for more detailed information pls refer to the user guide, if you coudln't find the user guide, pls tell me what OS you use, I can send the user guid to you for reference
philhale
Phil
philhale
Problem was that the SD Card was not properly imaged. Re-imaging the SD Card resolved the problem. This happened to me with two different i.MX6ULL EVK's.
