HI Team,
I have MCIMX6SX-SDB board, it comes with a SD card with image that boots with linux and openembedded image.
> I need the link to download the pre built image which come with package
> Also i need flashing instruction.
Solved! Go to Solution.
you can download the images from the link as below:
for flashing instrutions, try to download the documents which has the same version as your pre-built images verion, then refer to the linux user guide
