MCIMX6D6 DDR 如何降频(How to down the DDR running frequency
1,524 次查看
zoujiamin
How to down the DDR3 running frequency ?  IMXd6,  Linux
我们的板子调试总出问题,  现在想降低DDR3的运行频率,  请问该如何操作? 谢谢.
4 回复数
1,515 次查看
Rita_Wang
Which board are you using? Which frequency are you using now?
1,504 次查看
zoujiamin
IMX6d6   , self made board.  DDR3 528MHz.  We made more than there hundred  boards .  About half of them hanged up after running several hours. Now we want to  run it at a lower DDR frequency
1,489 次查看
Rita_Wang
For our reference board, the 400MHz is the ideal value. The DDR frequency support depend on hardware design. Here recommend you to use the 400MHz or lower for you board.
1,484 次查看
zoujiamin
Thank you for reply!
Today,  we found the board can ran stably when switch off the CPU1. It's strange.  We cann't konw what happened . and don't know what's the problem. We tested the supply, it's very good.
