I'd like to ask about possible side-effects of lowering LDO_1P1 voltage below its default value of 1.1V.
i.MX 6ULL datasheet ( IMX6ULLIEC Rev. 1.2) states that "Typical Programming Operating Range is 1.0V to 1.2 V". Does it mean it's totally safe to set this voltage to 1.0V?
解決済! 解決策の投稿を見る。
Hi Evgeny
yes values provided in datasheet are safe, however setting to lower limit
may be unsafe due to ldo tolerancies, so some margin is needed.
Hi Evgeny
Thank you! May I know what exactly this LDO tolerance is? Unfortunately I couldn't find this information in the datasheet.
Is 25mV enough to account for the LDO tolerancies?
it is about 2-3%.
