I'd like to ask about possible side-effects of lowering LDO_1P1 voltage below its default value of 1.1V.
i.MX 6ULL datasheet ( IMX6ULLIEC Rev. 1.2) states that "Typical Programming Operating Range is 1.0V to 1.2 V". Does it mean it's totally safe to set this voltage to 1.0V?
已解决! 转到解答。
Hi Evgeny
yes values provided in datasheet are safe, however setting to lower limit
may be unsafe due to ldo tolerancies, so some margin is needed.
Hi Evgeny
