Low/High width of GPIO input
2,112 次查看
takayuki_ishii
Hello community,
We hope to use a gpio input for external interrupt.
To detect low input as interrupt by GPIO module, how long does it keep low level?
How about rise/fall edge detect setting?
The other hands, we hope to know how long it must keep Hi/Low level
for general purpose input signal?
It has a same question in this thread.
      About GPIO external interrupt
But no answer it have.
Don't you have some information about it?
Ishii.
标记 (1)
1,883 次查看
Carlos_Musich
Hi Takayuki,
you may look in the datasheet for the Slew Rate parameter (E.g. Table 28 and Table 29 in IMX6DQCEC.pdf). This will indicate the time required for a signal to be considered a real value and that is the minimum time the signal must remain unchanged.
Carlos
NXP Technical Support
1,884 次查看
Carlos_Musich
Hi Takayuki,
Carlos
1,883 次查看
takayuki_ishii
Hello Carlos,
Thank you for your response.
I will ask it to my customer.
Ishii.
1,883 次查看
takayuki_ishii
Hello community,
Does anyone have any information?
Ishii.
