Tried to login via serial to Freescale I. Mx Quad/Lite, it all ways shows up
imx6xstd-login:
and
password:.
I entered "root" and "root" didn't work.
I entered "root" and left the password empty.
Didn't work too.
Can anybody help? THANKS
I mean set user/password as linaro/linaro , you also can refer to my another topic, try to change the root password, since I'm not sure what bsp you use
what bsp do you use? how about "lucid" or " linaro"?
Tried User name lucid and linaro, with password root and tried with empty password.
The item is a car head unit called naceur wave 2 from continental.
The board is named wave2.
The password is "root", could you tell us which board and which version of BSP are you using?
