Load signed u-boot on secure board through JTAG
mohamed-ali_fod
I want to load signed u-boot using JTAG on imx6 processor. The same below steps work fine after DDR initialization but, the u-boot run and I can get console only on non secure board, but it doesn't run on secure board (SECURE_CONFIG bit enabled). For information I already check that the signed u-boot works fine on another secured board.
loadbin ./u-boot-spinor-signed.imx.bin 0x177ff400
SetPC 0x17800000
g
Downloading file [./u-boot-spinor-2020.04-r1.imx.bin]...
O.K.
VerifyBin ./u-boot-spinor-signed.imx.bin 0x177ff400
Loading binary file ./u-boot-spinor-signed.imx.bin
Reading 689472 bytes data from target memory @ 0x177FF400.
Verify successful.
As mentioned above the load works well on secure and non secure board but the loaded u-boot works only on non secure board.
Could you please help? Are the 0x17800000 or 0x177FF400 addresses still valid in case of secure board?
Mohamed Ali
Dhruvit
Hi @mohamed-ali_fod,
I hope you are doing well.
->You need some u-boot executable that's been built to work on the board.
-> Please check the below documents for your reference.
http://imx6dev.blogspot.ru/2014/07/inexpensive-jtag-on-imx6-solo-u-boot.html
Thanks & Regards,
Dhruvit Vasavada
mohamed-ali_fod
Hi Dhruvit,
Of course I have functional u-boot that works for this board , it works if the u-boot is flashed in the flash memory. Also the same u-boot works fine for non secured board through jtag as I mentioned in my previous email (u-boot-spinor-signed.imx.bin). But my question why this u-boot doesn't work through jtag in secured board (secure_config fuse enabled), what could be the difference vs non secure board.
I hope the question is clear.
Thank you in advance,
Mohamed Ali
Dhruvit
->Can you let me know if secure JTAG is enabled or not?
->Please verify whether the CSF file had the correct UID.
->Please refer to 5.2.13.1  Unlock Examples in Code-Signing Tool User’s Guide
https://www.nxp.com/webapp/Download?colCode=IMX_CST_TOOL_NEW
Thanks & Regards,
Dhruvit Vasavada
mohamed-ali_fod
Hi @Dhruvit
The secure JTAG is not enabled I enabled only secure_config fuse.
Is it mandatory to add UID in CSF to load signed u-boot through jtag?
Please note that my signed u-boot is working well on my board if the board boot from memory flash, my problem is to boot the board using signed u-boot loaded through jtag.
Mohamed Ali
Dhruvit
One needs to enable Secure JTAG mode on a closed device.
It limits the JTAG access by using a challenge/response-based authentication mechanism.
Please refer to Secure Debug in i.MX 6/7/8M Family of Applications Processors for more information.
Thanks & Regards,
Dhruvit Vasavada
