Linux for IMX8 : switch to virtual console
4,748 次查看
tan-k
I need to switch to virtual console.
I try, but have an issue. Cannot switch to virtual console sometimes.
Could you please tell me this solution?
About details, please refer below.
[Environment]
Evaluation Kit : 8MMINILPD4-EVK (Connect HDMI cable, USB keyboard and USB mouse.)
Linux for i.MX : Linux 5.4.70_2.3.0​ (Download "L5.4.70-2.3.0_images_MX8MMEVK.zip" and flash "imx-image-full-imx8mmevk.wic" to SD card.)
[Procedure]
1.Trun on the power to evaluation kit. Then boot from SD card.
  ->Wayland Weston desktop is shown on the screen.
2.Press "Ctrl + Alt + Fn1(or Fn2-Fn6)" key to switch to virtual console.
  ->Virtual console screen is shown for a second, then Wayland Weston desktop is shown.
    Move the mouse, but the pointer on the screen does not move.
3. Press "Ctrl + Alt + Fn7" key to return Wayland Weston desktop.
  ->Move the mouse, the pointer on the screen moves normally.
4.Click weston-terminal icon on toolbar and execute weston-terminal. Input some keys on terminal.
  Then press "Ctrl + Alt + Fn1(or Fn2-Fn6)" key to switch to virtual console.
  ->Can switch to virtual console normally.
5. Press "Ctrl + Alt + Fn7" key to return Wayland Weston desktop.
  ->Wayland Weston desktop is shown.
6.Press "Ctrl + Alt + Fn1(or Fn2-Fn6)" key to switch to virtual console again.
  ->Same result as procedure 2. Then input some keys.
7. Press "Ctrl + Alt + Fn7" key to return Wayland Weston desktop.
8.Click weston-terminal icon on toolbar and execute weston-terminal. Input some keys on terminal.
    And keys which I input at procedure 6 are shown virtual console screen.
I think there is issue when switch the screen.
Switching control works normally because we can input key.
Any help would be appreciated.
Thank you.
4,519 次查看
Zhiming_Liu
The patch has been attached.
10 回复数
4,009 次查看
josephzhou1
good
Joseph Zhou Jianhui / Senior Embedded Software Engineer, Singapore
4,024 次查看
JoeChen
We have met the similar problem, but our Linux kernel is 4.14.98; could you also provide a patch solution to us?
Thank you very much!
BR,
Joe Chen.
4,520 次查看
Zhiming_Liu
4,501 次查看
tan-k
This problem was solved after applied your patch.
Thanks to your support!
4,722 次查看
Zhiming_Liu
I have confimed this issue.It seems weston bug.You can see the mouse can not move because the visual console is opened,but the weston don't show.I am trying to find out the problem.
Zhiming
4,712 次查看
tan-k
Thank you for your reply !
I look forward to additional information !
4,648 次查看
Zhiming_Liu
Hi tan-k
This bug is report to expert team and waiting for their reply.
4,631 次查看
tan-k
Thank you for telling me current situation.
We hope expert team solve this bug.
4,606 次查看
Zhiming_Liu
This bug has been posted to software team waiting to be fixed
Zhiming
4,599 次查看
tan-k
Thank you!
We hope software team fix this bug quickly.
