Linux_Multimedia_Framework_User_Guide.pdf(imx6 )
3,456 次查看
andypeng
Hi all,
  Linux_Multimedia_Framework_User_Guide.pdf.
  Installing/Building the Plugins on Ubuntu
1.1.4  Installing/Building the Plugins
2.  Install BSP support libraries package, the package is released with BSP. (you need to
have the .deb file available to the board, a USB-Key or copying the file to the board in
some other way should be fine)
sudo dpkg -i imx-lib-$VERSION-$RELEASE.deb
sudo dpkg -i kernel_$VERSION-imx_$RELEASE_armel.deb
It is desired to install all other BSP Debian packages.
where is the packages that is released with BSP?I can't find any *.ded file in BSP.
Can anybody answer this question ?
标签 (2)
2,295 次查看
Yuri
5 回复数
2,295 次查看
andypeng
Hi Yuri Muhin ,
1. I already down load the BSP from:
https://www.freescale.com/webapp/Download?colCode=L3.0.35_1.1.0_MM_CODECS&appType=license&location=n...
http://www.freescale.com/webapp/sps/site/prod_summary.jsp?code=i.MX6Q&nodeId=018rH3ZrDRB24A&fpsp=1&t...
2.I already installed the LTIB for the BSP.
3.Now I want to use the linux Multimedia Plugins on Ubuntu, I refer to corresponding chapter in Linux_Multimedia_Framework_User_Guide.pdf.
In this document:
1.1 Building the Plugins with LTIB
1.1.2 Building the Plugins with LTIB
1.1.3 BSP Requirements
This chapter describes how to build and generate debian packages on the i.MX series board natively.
Following steps illustrate how to install Freescale Multimedia Plugins on Ubuntu and also how to build a Debian package from the source.
1. Prepare an i.MX6 board running Ubuntu OS(11.10 Oneiric)
2. Install BSP support libraries package, the package is released with BSP. (you need to have the .deb file available to the board, a USB-Key or copying the file to the board in some other way should be fine)
Now I don't found the packages for *.ded files in BSP(L3.0.35_1.1.0_121218_source)..
Pls tell me the imx-lib-$VERSION-$RELEASE.deb ,kernel_$VERSION-imx_$RELEASE_armel.deb where it is?
thank you
andy
在 2013-04-01 12:17:07,"Yuri Muhin" <admin@community.freescale.com> 写道:
created by Yuri Muhin in i.MX Community - View the full discussion
Please use codec package (Ubuntu case) :
Reply to this message by replying to this email -or- go to the message on Freescale Community
Start a new discussion in i.MX Community by email or at Freescale Community
2,295 次查看
Yuri
You may install all .deb package one by one.
2,295 次查看
andypeng
This imx-lib-$VERSION-$RELEASE.deb is it right? The following package:
imx-lib-test-ubt_[version]_armel.deb imx-lib-ubt0_[version]_armel.deb
but kernel_$VERSION-imx_$RELEASE_armel.deb ,I cannot know what it is ?
--andy
在 2013-04-03 12:24:58,"Yuri Muhin" <admin@community.freescale.com> 写道:
2,296 次查看
Yuri
