Linux Backports into LTIB
1,826 次查看
JeromeBaron
HI everyone,
I am working on a board with a imx28. Right now, I use the mx28EVK. I want to include a driver for a wireless lan chipset, the TI wl18xx. I want to use the linux backports package that can be found here:
https://backports.wiki.kernel.org/index.php/Main_Page
I want to include this in my LTIB package, but I don't understand how to make it appear in the menuconfig. I know I must do a backports.spec file in my folder in dist\lfs-5.1\backports but I dont know what to put in it. I saw on the backports wiki the "build section" to put in this file, but I can find the rest of the file.
Not sure if I need to include this folder in another file to make it appear in the configuration screen of ltib.
Jerome
*I succesfully modified packages.lkc and pkg_map to add the package to the config screen. For now, it wont compile because of the build section.
Message was edited by: Jerome Baron
1,596 次查看
igorpadykov
Hi Jerome
I think attached appnote may help.
1,597 次查看
igorpadykov
Hi Jerome
