Layout guide line for uSDHC with SDR104 mode in i.MX6
3,493 次查看
keitanagashima
Senior Contributor I
Dear Sir or Madam,
Hello.
My customer would like to use the uSDHC interface with SDR-104 mode.
This mode is very fast speed (104 MB/s max).
Do you have Layout guide line for uSDHC with SDR104 mode in i.MX6?
BR,
Keita
标签 (5)
2,753 次查看
Hi Keita
i.MX6 User Guide does not provide special recommendations
for SDR-104 mode layout. However one can use sect.
3.12 Impedance signal recommendations IMX6DQ6SDLHDG and
sect.6 SD/MMC/SDIO Card AN4215 i.MX28 Layout Guidelines
(given also for double data rate mode).
2,754 次查看
Hi Keita
2,753 次查看
keitanagashima
Hi Igor,
Thank you for your reply.
I found the below description on HW Design Checking List for i.MX6DQSDL
"50Ω impedance control"
"Match Clock and Data signals  ± 50 mils"
Is it possible to reference above descriptions, too?
Keita
2,753 次查看
Hi Keita
yes one can also use this document too, as
"summary based on IMX6DQ6SDLHDG and our supporting experience"
