LVDS settings for 2 channel, 8 Bit
3,206 次查看
johnturnur
I am using 1920x1080 LVDS panel.
But i am not getting output for 2 channel, 8 bit LVDS.
What setting is requied for this?
My panel specifications are metioned in attached file.
John.
2,267 次查看
max_tsai
Generally, if your bootargs includes "video=mxcfb0:dev=ldb,LDB-XGA,if=RGB666,bpp=32", then you need to modify ldb_modedb  of "./drivers/video/mxc/ldb.c".
You may refer to "kernel/Documentation/fb/framebuffer.txt" for the detail.
2,268 次查看
max_tsai
