Tried adding the string from cat /sys/class/graphics/fb0/mode to /system/etc/display_mode_fb0.conf as well
root@sabresd_6dq:/ # cat /sys/class/graphics/fb0/mode
U:800x480p-60
Suspected logs
01-01 05:30:26.594 1661 1724 W Launcher.Model: Desktop items loading interrupted:
01-01 05:30:26.594 1661 1724 W Launcher.Model: java.lang.ArrayIndexOutOfBoundsException: length=5; index=5
01-01 05:30:26.594 1661 1724 W Launcher.Model: at com.android.launcher2.LauncherModel$LoaderTask.checkItemPlacement(LauncherModel.java:1230)
01-01 05:30:26.594 1661 1724 W Launcher.Model: at com.android.launcher2.LauncherModel$LoaderTask.loadWorkspace(LauncherModel.java:1393)
01-01 05:30:26.594 1661 1724 W Launcher.Model: at com.android.launcher2.LauncherModel$LoaderTask.loadAndBindWorkspace(LauncherModel.java:103)
01-01 05:30:26.594 1661 1724 W Launcher.Model: at com.android.launcher2.LauncherModel$LoaderTask.run(LauncherModel.java:1133)
01-01 05:30:26.594 1661 1724 W Launcher.Model: at android.os.Handler.handleCallback(Handler.java:739)
01-01 05:30:26.594 1661 1724 W Launcher.Model: at android.os.Handler.dispatchMessage(Handler.java:95)
01-01 05:30:26.594 1661 1724 W Launcher.Model: at android.os.Looper.loop(Looper.java:148)
01-01 05:30:26.594 1661 1724 W Launcher.Model: at android.os.HandlerThread.run(HandlerThread.java:61)
01-01 05:30:28.795 1661 1661 D Launcher.Model: Reload apps on config change. curr_mcc:404 prevmcc:0
01-01 05:30:31.573 1661 1724 W Launcher.Model: Desktop items loading interrupted:
01-01 05:30:31.573 1661 1724 W Launcher.Model: java.lang.ArrayIndexOutOfBoundsException: length=5; index=5
01-01 05:30:31.573 1661 1724 W Launcher.Model: at com.android.launcher2.LauncherModel$LoaderTask.checkItemPlacement(LauncherModel.java:1230)
01-01 05:30:31.573 1661 1724 W Launcher.Model: at com.android.launcher2.LauncherModel$LoaderTask.loadWorkspace(LauncherModel.java:1393)
01-01 05:30:31.573 1661 1724 W Launcher.Model: at com.android.launcher2.LauncherModel$LoaderTask.loadAndBindWorkspace(LauncherModel.java:103)
01-01 05:30:31.573 1661 1724 W Launcher.Model: at com.android.launcher2.LauncherModel$LoaderTask.run(LauncherModel.java:1133)
01-01 05:30:31.573 1661 1724 W Launcher.Model: at android.os.Handler.handleCallback(Handler.java:739)
01-01 05:30:31.573 1661 1724 W Launcher.Model: at android.os.Handler.dispatchMessage(Handler.java:95)
01-01 05:30:31.573 1661 1724 W Launcher.Model: at android.os.Looper.loop(Looper.java:148)
01-01 05:30:31.573 1661 1724 W Launcher.Model: at android.os.HandlerThread.run(HandlerThread.java:61)
