LVDS camera on imx8m plus mipi-csi interface
2,397 次查看
chp0423
Does mipi-rx interface of imx8m plus support LVDS raw camera? The camera has a one-lane lvds output.
4 回复数
2,379 次查看
Irene
NXP Pro Support
NXP Pro Support
I will look into this issue.
2,364 次查看
Irene
NXP Pro Support
NXP Pro Support
On the I.MX 8M Plus, below are the connectors available.  Which connector are you referring to?
2,349 次查看
chp0423
I am using the Camera MIPI-CSI connector. I have successfully driven a two-lane mipi sensor with this connector, but my new sensor only has one-lane LVDS output, and I wonder whether I can directly connect this LVDS sensor to the CSI connector.
2,337 次查看
Irene
NXP Pro Support
NXP Pro Support
Please clarify what you mean by "you have successfully driven a two-lane mipi sensor with this connector?" Which connector are you referring to here?
I assume you would need some bridge to convert LVD to MIPI or serializer to de-serializer converter.
