LVDS camera on imx8m plus mipi-csi interface
chp0423
Does mipi-rx interface of imx8m plus support LVDS raw camera? The camera has a one-lane lvds output.
Irene
NXP Pro Support
NXP Pro Support
I will look into this issue.
Irene
NXP Pro Support
NXP Pro Support
On the I.MX 8M Plus, below are the connectors available.  Which connector are you referring to?
chp0423
I am using the Camera MIPI-CSI connector. I have successfully driven a two-lane mipi sensor with this connector, but my new sensor only has one-lane LVDS output, and I wonder whether I can directly connect this LVDS sensor to the CSI connector.
Irene
NXP Pro Support
NXP Pro Support
Please clarify what you mean by "you have successfully driven a two-lane mipi sensor with this connector?" Which connector are you referring to here?
I assume you would need some bridge to convert LVD to MIPI or serializer to de-serializer converter.
