I have a brand new i.MX53 Sabre (ARD) board. When I use the factory linux SD to boot, the ethernet controller is found, and the u-boot command "dhcp" works. After using LTIB to create u-boot, linux kernel, and linux rootfs SD card, and booting with that SD card, the u-boot monitor reports Net: smc911x: Invalid Chip endian 0x7fbf7fbf. Then, tried to use factory linux SD again, and problem remains. Something incorrect has persisted. Anyone seen similar issue and know how to repair? I'm using u-boot 2009.08 with recent "./ltib -prep -p u-boot" command.
Thanks, Al.
