LTIB i.MX51 Platforms doesn't appear in ltib configuration ?
994件の閲覧回数
G_rio
Could anyone help me with this issue ?
Thank you
タグ(2)
4 返答(返信)
863件の閲覧回数
G_rio
This error was solved reinstalling ltib.
863件の閲覧回数
LuisCasado
After installing the BSP. Just run ./ltib  and you will get the configuration screens. You can use ./ltib --selectype and make configuration across screens.
863件の閲覧回数
G_rio
I run LTIB after set permission on folder and i run this cmd
./ltib --preconfig config/platform/imx/imx51.cf --batch --dlonly --noredir
Luis Casado said:
Select that option, Freescale i.Mx reference boards and Exit
Then, in the next screen configuration Select imx5x and the profile you want (Min, Gnome,...) And Exit
In the next screen configuration select your board: mx51_bbg in your case, exit and build the image.
863件の閲覧回数
LuisCasado
