I run LTIB after set permission on folder and i run this cmd
./ltib --preconfig config/platform/imx/imx51.cf --batch --dlonly --noredir
Luis Casado said:
Select that option, Freescale i.Mx reference boards and Exit
Then, in the next screen configuration Select imx5x and the profile you want (Min, Gnome,...) And Exit
In the next screen configuration select your board: mx51_bbg in your case, exit and build the image.
