LTIB Config failed On ubuntu12.04
1,457 次查看
jiohe
Hi all.
       I was build ltib in L3.0.35_4.1.0_130816_source.tar.gz for imx6.
       My platform is ubuntu 12.04 .
       I have patched "patch-ltib-ubuntu12.04.sh"  and install the packages which refered in "ltib_build_host_setup".
       But I still encounter an error .
        Here is my host_config.log.
Processing platform: host support
Processing: rpm-fs
ERROR: /tmp/rpm-hedajun/RPMS/i686/rpm-fs-4.0.4-1.i686.rpm
would clobber '/reescale/ltib'
traceback:
main::check_host_clobber:2693
  main::build_rpm:918
   main::f_buildrpms:992
    main::check_rpm_setup:2424
     main::host_checks:1435
      main:554
  I have searched on the community get no answer..
please help!
标签 (3)
1 回复
1,053 次查看
jiohe
I have resolve the problem by
#  rm /tmp/rpm-hedajun/RPMS/i686/rpm-fs-4.0.4-1.i686.rpm
and now config successfully
but why can't I find the document of L3.0.35_4.1.0_130816_source? where is it ?
